« Reply #11355 on: January 26, 2020, 12:20:03 AM » |
Also fitted 2 new residual valves, (colour coded, red for the rear drums & black for the front discs).
And how are you going to remember which is which?
« Reply #11356 on: January 26, 2020, 09:44:17 AM » |
Yeah, somehow I've got to work out where the various brake pipes go & I've got no idea! I labelled the servo so I know which pipe goes to which connector on the bulkhead & I know I made a note somewhere of the rest, but can't remember where I put the note. I may have to trawl back through the forum & see if there's a photo showing which port on the servo was the front brakes & which was the rear.
« Reply #11357 on: January 26, 2020, 05:52:38 PM » |
I do believe the outlet at the front (furthest from you foot pedal/bulkhead? ) is normally the front brake pipe?
« Reply #11358 on: January 26, 2020, 08:40:09 PM » |
Nope, checked with Kev, (Kapri), & Chris, (Funky Hiboy), & the front one's the rear brakes!
« Reply #11359 on: January 26, 2020, 09:06:34 PM » |
50/50 chance 🤣👍
« Reply #11360 on: January 27, 2020, 04:31:11 AM » |
you'll know for sure at the first stop sign!
I hate when people compare Lemmy with God, i know he is great but he is not gonna be Lemmy, ever If your Dad hasnt got a beard, you've got two Mums there's no point it lookin' pretty if we can't drive it.
« Reply #11361 on: January 27, 2020, 04:22:00 PM » |
« Reply #11362 on: January 29, 2020, 09:53:58 PM » |
Bolting random stuff back in place -& finding I've either lost the bolts or they've corroded & need replacing. My local toolshop are getting fed up of me arriving with shopping lists of stainless fasteners. 1/2" spacer fitted behind the brake residual valves to bring them into line with the brake light switch. I wonder if I can flare the ends on a brake pipe that short?
« Last Edit: January 30, 2020, 09:33:27 AM by Manky Monkey »
« Reply #11363 on: January 29, 2020, 09:55:54 PM » |
Gearstick fitted for no other reason than I found it in a box of parts. The engine & box aren't properly fitted at the moment, which is why it's sat at an angle.
« Reply #11364 on: January 29, 2020, 09:58:27 PM » |
Most of this stuff was either in bare metal or just brush painted last time the Pop was running, so has been powder coated black at some point in the last 7 years while it's been off the road.
« Reply #11365 on: January 29, 2020, 10:00:41 PM » |
Various things bolted to the frame under the dash. Wiper motor, windscreen washer pump & servo, which I'm still fighting with cos the mounting bolts are a bugger to get to.
« Reply #11366 on: January 29, 2020, 10:01:12 PM » |
« Reply #11367 on: January 29, 2020, 10:02:46 PM » |
I've also bolted on the top pair of 4 bar locating rods for the back axle, just to see how they look.
« Reply #11368 on: January 29, 2020, 10:16:07 PM » |
It's all progress! And the best way of not losing the parts again!
« Reply #11369 on: January 30, 2020, 08:12:16 AM » |
Just don't scratch anything 😱😁
