May 05, 2024, 11:51:22 AM
General Tech
Rocker cover dimensions.
Topic: Rocker cover dimensions. (Read 3674 times)
February 17, 2014, 12:35:20 PM »
Does anyone know (or can measure) the Rocker cover dimensions of the Triumph 1300/1500 as fitted to spits & midgets etc.
Not worried about the fixing hole centres, just the overall flange dimensions.
Cheers - Olds
Re: Rocker cover dimensions.
February 18, 2014, 03:00:59 PM »
Now sorted. Thanks Steve
Was hoping that an alloy one could be modified to fit Reliant. Correct width but 1 1/2" too long
Might look into shortening one to fit, or perhaps getting some cast.
February 18, 2014, 03:06:40 PM »
Had you asked Dave, Id've told you that!
The Reliant owners club had a limited run cast in ali. Very thick, (almost a quarter of an inch), & plain -no ribs. I had one on my last trike. Bought it through the owners club for 50 quid.
February 18, 2014, 04:04:48 PM »
Knew it wouldn't fit without some modification but was hoping that it would be a bit closer.
The Reliant ones aren't exactly pretty and are very expensive if you can find one.
February 18, 2014, 10:12:38 PM »
I'll be watching this with bated breath
February 18, 2014, 11:04:38 PM »
Something like this.
stumpy
Reply #6 on:
February 24, 2014, 07:48:32 PM »
Why not cut it to size and weld out back together?
Reply #7 on:
February 24, 2014, 08:21:25 PM »
Quote from: stumpy on February 24, 2014, 07:48:32 PM
Thought about that and if I could do it properly it might be worth a try. I recon that I'd just ruin a £50 rocker cover. Looking into alternatives.
