May 17, 2024, 09:34:37 PM *
Pages: 1 ... 44 45 [46] 47 48 49
Author Topic: my new trike project  (Read 200801 times)
Baychimp
« Reply #675 on: August 10, 2015, 10:23:03 PM »
Well done Craig. You really have made it your own now. Brilliant engineering by Mr Stumpy, another very clever man.
« Reply #676 on: August 10, 2015, 10:41:57 PM »
Nice to see that the 'old skills' are not in fact...dead Cheesy.......tidy Mr. S....Morrag
twisted
« Reply #677 on: August 11, 2015, 10:45:56 AM »
thanks alot guys. really enjoying riding her just want to be out more. maybe move away further from my workplace  Grin
« Reply #678 on: August 11, 2015, 12:41:38 PM »
Dorset is nice..only 1hour 40 mins to northolt ?
andyrennison
« Reply #679 on: August 11, 2015, 07:11:03 PM »
Very very very nice. Did I mention  very?. Good one guys.
goose
« Reply #680 on: August 12, 2015, 06:42:38 PM »
brilliant job and sounds sweet , well done stumpy , sorry,  sir stumpy .. Wink Wink
twisted
« Reply #681 on: August 12, 2015, 10:48:07 PM »
Might be a little to far there stinky but will think on it  Wink
Cheers andy and goose  Wink
Noticed a little bit of oil at the bottom of the diff today from where we had split it  Shocked.
Cleaned it up then remembered that when we had it apart we looked over the axle but could not find a breather hole. Never remember seeing one.Think it might have been sealed over with weld or paint.
Thought it could be building pressure and pushing out oil!
Got a 2mm drill bit and put a hole in the axle tube to let it breath, will find a split pin to put in it to help keep crap out. Gave the diff a lick of paint to to help seal it to. Smiley
Have started to make a grill to protect the rad.
twisted
« Reply #682 on: August 17, 2015, 09:41:05 AM »
before going to popham at the weekend i made and fitted a rad grill to stop stones smashing in to the front of the rad. galvanized steel grill and push on rubber edging.
also had the tank off for a bit of sanding and spraying. you can see the all thats been fitted skillfully under there.
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150813_182535_zpsndevklvi.jpg
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150813_182516_zpscpvxx55o.jpg
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150814_133751_zps8yegzdoo.jpg
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150814_200658_zpsoyt3mh6n.jpg
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150814_200620_zps0dmltuas.jpg
putting the paint on has helped show up where i need to do more work and will help stop it rusting while i do it  Wink
« Reply #683 on: August 17, 2015, 05:40:51 PM »
Good to see you out on it yesterday young sir Cool
« Reply #684 on: August 17, 2015, 07:01:20 PM »
Great to see it at the show mate. Massive change and looks good, but you are still a heathen heretic !  Grin
twisted
« Reply #685 on: August 20, 2015, 10:42:16 AM »
thanks gentlemen, great seeing you all and a heathens not that bad  Grin been called worse. just glad you all still spoke to me  Smiley
well i need to fit a light for my alarm and a temperature warning light as one was fitted on the original bike. bought a couple of led's and made a new bracket to hold them.
wired and heat shrunk them in.
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150818_182526_zpsldyzadkh.jpg
http://i1201.photobucket.com/albums/bb347/twistedspirit76/mobile%20pics/mankey%20monkey%20motors/my%20trike/20150818_182538_zpshosespmw.jpg
only thing now is after putting it all back together my marker lights are flashing with my indicators  Shocked Sad. will be looking at it on my lunch break and after work.
« Reply #686 on: August 20, 2015, 07:58:58 PM »
nice looking .the high tank looks good
twisted
« Reply #687 on: August 21, 2015, 08:18:23 AM »
cheers scannerzer  Wink
sorted out the markers going off with my indicators  Grin nothing to do with what i had just put in but part of the old loom. hazards still not right, still going off like a strobe at a rave but think the flasher unit might be faulty so will get a new one and fingers crossed that will fix it.
twisted
« Reply #688 on: January 04, 2016, 03:46:51 PM »
well with some time over christmas decided it an ideal opportunity to get to now my engine more intimately  Shocked Wink
she has had a problem with oil going missing when i do longer harder runs, 120 miles + at motorway speeds. compression was down a bit to. suspected that the valve stem seals might be to blame.
so before christmas purchased full gasket kit, rings, oil, oil filter, sealant and clutch cover (old one had a hole which had been filled)
so after a good friend came to help and 17 hours graft we had the engine out, stripped, rings in, valves lapped, gaskets in, back together and back in the frame. Tongue Grin
am running her in a bit but she already sounds better (not sure my neighbors will be keen on that  Grin) give it a couple more weeks of running in then will do a compression test to check and a long to see if she has kicked her oil drinking habit. fingers crossed.
« Reply #689 on: January 04, 2016, 07:31:34 PM »
Hiya Craig. Nice to see you back matey. Sounds like you've been busy!
