May 06, 2024, 01:23:26 AM
Trike Tech
ABS
Topic: ABS (Read 2178 times)
ABS
May 10, 2018, 10:54:39 AM »
Looking to possible next project, Honda ST1300.
The bikes supplied for UK have abs fitted. I would look to remove when converting to trike.
Is this doable?
Living on a wing and a weld
toad
Re: ABS
May 10, 2018, 06:31:29 PM »
Yes you can just by unplugging the sensor wires but it will put the abs light on the dash under new mot laws it will fail a test.
Re: ABS
May 11, 2018, 10:45:19 AM »
That's easily sorted as the dash light could be done away with.
dr big750
Re: ABS
May 11, 2018, 01:09:26 PM »
Or you could fit an abs ring to one side and it may work if speeds are near equal.
Where is the original rear pickup senser?
Re: ABS
May 11, 2018, 07:09:15 PM »
Interesting, however looking at the price for all the abs parts that are on the bike, I think I would like to simplify the installation.
Plus, the weight saving would be huge!
Plus plus if the abs isn't there it can't be tested.
Last Edit: May 12, 2018, 06:17:15 AM by paulywombats
