Dicky
No refund's
« Reply #15 on: September 14, 2008, 09:28:51 PM » |
Sorry tbone, , the dimension for the distance between the caliper bracket mounting holes and the center of the large diameter hole is missing (53mm between centers). Glad you had a go, I was going to try doing it on Visio tomorrow.
So I said to God, "If this is it (life), you can keep it." And God said, "Just be glad you got the heart by-passes in time. I don,t normally give refunds".
« Reply #16 on: September 14, 2008, 09:40:40 PM » |
True its not noted, but as it is a 1:1 scale template i omitted it, you`ll find its spot on when printed. Consider it now ammended to include the aformentioned
« Last Edit: September 14, 2008, 10:06:02 PM by tbone »
tony b
« Reply #17 on: September 14, 2008, 10:11:56 PM » |
shabba ,ill have one if you dont mind ,ill pm you my friends number,thank you in advance,tony b.
« Reply #18 on: September 14, 2008, 10:37:14 PM » |
Thanks for sorting that TBone. All day working on it? You do realise we don't pay don't you?! The last pair of plates we had are fitted to Taz's axle so when the paper template arrives, I'll slit it to fit around the drive shaft & lay it over the steel plate. if it's a good fit we're in business.
« Reply #19 on: September 14, 2008, 10:49:27 PM » |
No wages again, a well you cant do enough for a good boss . Never used a CAD programme before today, now i can do them wih my eyes shut . I used a free CAD programme which must be easy if i can do it, trouble is, it has limited functions, like not being able to export the files you draw.Great if you wanna print them off but no good for sharing!
« Last Edit: September 14, 2008, 10:53:01 PM by tbone »
« Reply #20 on: September 14, 2008, 11:26:19 PM » |
We're happy to print a bunch off to post out to those that ask for them -or pay you to print them off for us?
« Reply #21 on: September 14, 2008, 11:36:13 PM » |
I already have a couple of requests, think i can run to a stamp or two . Am working on an idea for posting the file but i`m away till thursday now so will look at that when i return.
tony b
« Reply #22 on: September 16, 2008, 10:53:15 PM » |
hi tbone the print outs arrived today, many many thanks mate i owe you ,regards tony b,shabba.
« Reply #23 on: September 16, 2008, 11:03:30 PM » |
Received the prints today TB, but not had a chance to try them against the plates on Taz's trike yet. One thing Brock pointed out to me -could do with the hole centres being marked.
tony b
« Reply #24 on: September 17, 2008, 01:58:29 PM » |
ill get me cumpass out and mark them on me new printouts,shabba,tony b.
Hagar
« Reply #25 on: September 17, 2008, 05:03:30 PM » |
Evening , Am working on an idea for posting the file but i`m away till thursday now so will look at that when i return.
Tbone ....if your plan to post the file does not pan out any chance of getting a print of the plan ? cheers .. Hagar
" When you have to kill a man , it costs nothing to be polite. " .. Winston Churchill
« Reply #26 on: September 18, 2008, 04:13:56 PM » |
Noted and hole centres now added. The pdf below shows a better (mk2) drawing, but DOES NOT print to scale. Attempted to post and print the file but the the print looses 2mm somehow??? It appears you dont need a CAD programme to print the file, just a CAD viewing programme, of which there are lots available as shareware or freeware, so if anyone has these the file can be emailed to and opened by them. Failing that, we are back to me printing it off.
« Last Edit: September 18, 2008, 05:27:20 PM by tbone »
