May 13, 2024, 10:56:28 PM *
Pages: 1 ... 5 6 [7]
Author Topic: Project Resurrection (question page 5)  (Read 22317 times)
geordi
« Reply #90 on: April 02, 2010, 08:41:32 AM »
Thanks Manky
This engine I'm planning  a full rebulid over the summer.
It's just good to know it wasn't a major componant that has broken
rite off to Essex to try to move the collour and get the axel working.
He sez in a hopefull voice
geordi
« Reply #91 on: April 02, 2010, 07:10:31 PM »
Well had a productive day, we have well and truly f**ked the axel  Embarrassed
Managed to get another on off evil bay picking it up tomorrow,  Smiley
Now the plan is to cut if axel off, get a friend to make up some axel clamps and get this back end back together,
Think were going to leave the rear brakes as drums for the time being
« Reply #92 on: April 02, 2010, 07:20:21 PM »
Well at least that's a decision made!
Did you find out what the problem was?
geordi
« Reply #93 on: April 02, 2010, 08:19:16 PM »
No
as the old axel is welded in. When I cut it off the frame I might take it appart and have a look
geordi
« Reply #94 on: April 04, 2010, 07:24:06 PM »
Picked up the Axel from a place called go on and have a guess
Monkey Farm, of all things
Guess the next part of the project is to remove the old axel and get this one welded in,
« Reply #95 on: April 05, 2010, 12:48:31 AM »
They farm monkeys? That's just wrong.
geordi
« Reply #96 on: April 10, 2010, 07:05:37 AM »
Taking of pix I opened up the rocker cover on one of my engines, and there were some bits loose and broken in there
Can anyone let me know what this is (apart from broken)
http://img.photobucket.com/albums/v108/Geordi/Trike/IMG_0420.jpg
http://img.photobucket.com/albums/v108/Geordi/Trike/IMG_0419.jpg
just about to order my gasket kit. Are these a push on type valve
stem seals
 they don't look like the top hat style
thus making this engine leaded
geordi
« Reply #97 on: April 17, 2010, 01:29:04 PM »
Over the bank hol I plan on stripping cleaning and rebuilding the head of one of my engines
having a look at it today the rocker cover looks like it was blue at some point in time
I know that originaly diffrent rocker covers ment diffrent engine specs
dose anyone know what the blue rocker cover ment??
I'm going to start to soak the bolts on penettrating fluid
apart from wd40 can anyone recomend a better one
thanks In advance
geordi
« Reply #98 on: April 17, 2010, 01:55:48 PM »
Just spent 10 mins cleaning some rust off the bolts and went over the rocker cover. Under the blue there is red paint as well
« Reply #99 on: April 17, 2010, 07:04:50 PM »
As far as I know red was the standard Reliant colour. The less common high compression engines had yellow covers -but there's no guarantee the cover is the one the engine left the factory with!
I always use WD40, simply because it's all I have to hand in my shed. Plusgas is good if you can find it.
« Reply #100 on: April 17, 2010, 07:48:29 PM »
Hi Geordi
Just a quick question. Are you sure this is one of Chalkys Trikes? Only reason I ask is that Chalky was the first member of our club to leave this mortal coil and I never remember him doing a tubular frame. The only ones I ever saw him do was all box section and normally with a Reliant front end on as well. I know it makes no real difference to your project and if it is it`ll be good to see a White trike back on the road.
geordi
« Reply #101 on: April 18, 2010, 09:22:25 PM »
Hi mate
I'll get my mate mark or goth on here to do a write up on the proper history of it
On another note making good progress
on prepping the lump ready for the head strip down over the bank hol
managed to loosen most of the nuts. On some of them the studs come out as the nust are well rusted on
where can I get new studs from?
Also the water pump is well and truly stuck any ideas on how I can remove it
if the water pump is stuck I think getting the head off will be a challenge
geordi
« Reply #102 on: May 02, 2010, 07:59:14 AM »
Had a great day yesterday, only thing I forgot to do was take any pictures
First of my mate Jon came ove and we decided to takle one fo the engines,
The first job after a cup of tea was to put up the gazebo, easy just follow the instructions, well
the instructions asked for parts A B C and D but we had 1 2 3 and 4, so with a little bit of monkey know how we got a shelterd work area set up
Then we asseblmed the engine stand, (£30 ebay) and tried to figure out where to put the mounts, we figured out we need to remove the cluch and fly wheel, thay came off without too much hassle
Got it mounted and on the stand, now onto the cleaning, we used gunk engine degreaser and I have to say it came up really well,
These is some pitting on the ally, but i'm going to go over it all again, this was just to get the most of the crap off the block,
geordi
« Reply #103 on: May 02, 2010, 08:04:14 AM »
While it was on the stand we though it would be a good idea to empty the sump,
well get got about .5l of fluid from the sump, .25 oil and .25 water,
Not impressed. What have I got here,
Well we might as well continue,
with the engine clean-ish we decided to take the rocker off and get the head off,
i'll finish off the right-up later
