May 14, 2024, 11:19:46 PM *
Pages: 1 [2] 3 4 ... 7
Author Topic: Misfire  (Read 31049 times)
flying pasty
« Reply #15 on: May 01, 2015, 05:23:36 PM »
Hi Terry
No i have`nt i will though, wouldn`t there be a milky texture on the inside of the rad cap if the head gasket has gone or not,
Hmm me thinks its off to the local garage in the morning to see when they can do the tests.
Robbie
« Reply #16 on: May 01, 2015, 05:28:57 PM »
A cracked valve seat could cause a misfire when eng is warm (crack opens up ) what fuel has been used prior to problem .leaded or unleaded?
flying pasty
« Reply #17 on: May 01, 2015, 05:30:15 PM »
Hi Rod
When the engine is running & up to temp if i try to open the rad cap it releases steam pressure, the rotor arm is new, this is the kit i got
http://www.ebay.co.uk/itm/181148279268?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The engine misfires wether it is cold or hot it doesn`t seem to make a difference to engine temp, also new temp sender unit.
Robbie
« Reply #18 on: May 01, 2015, 05:33:43 PM »
Carbon or copper leads? Doesnt say in ad.
flying pasty
« Reply #19 on: May 01, 2015, 05:34:32 PM »
Hi Rod
I have used unleaded since i got it last may 2014, but i am suspicious as a new bottle of lead additive was in the side box so i think it should be leaded, i do have the lead diamond blocks to go in the tank but not sure if i should use them as i was told it had been rebuilt ( engine that is ).
Robbie
flying pasty
« Reply #20 on: May 01, 2015, 05:36:39 PM »
Hi rod
I would say they are carbon
Robbie
« Reply #21 on: May 01, 2015, 05:36:48 PM »
Try running it in the dark, as I said.Ive had cars giving a light show un der the bonnet! I dont like carbon leads, others love them though.
Crazy thought ..is the dizzy cap seating correctly to the dizzy body? I had one that didnt, caused intermittent probs.
on another forum recently, the problem was the tiny earth wire to the points insidethe dizzy.also check the main engine earthwire is good.
« Last Edit: May 01, 2015, 05:45:06 PM by ROD » Logged
flying pasty
« Reply #22 on: May 01, 2015, 05:43:11 PM »
Hi Rod
The leads are a lot thinner than the original ones so i think they would be carbon, i will run it tonight when its dark in the garage to see if i got a light show around the engine.
yes i made sure the dizzy cap is seated firmly as a mate said about that.
Ok i will make sure its a good earth from the engine to the frame, the dizzy has electronic ignition & the earth wire is attached to the dizzy body & coil solid connection.
Thank you for all your help & advice guys, really appreciate it.
Robbie
« Last Edit: May 01, 2015, 05:49:23 PM by flying pasty » Logged
« Reply #23 on: May 01, 2015, 05:59:05 PM »
Woha! Its got elec ignition.has it got the rightrotor arm?  Think mine has a certain type for the elec ign? Not sure the one in that kit is correct? Also...have you tried fitting an original setofpoints? ..look at the old boys , er sorry fifers !website for tips on elec ign fitting.
Could the module be duff?
flying pasty
« Reply #24 on: May 01, 2015, 08:16:13 PM »
Hi Rod
This is the elec ign i got with no rotor arm,
http://www.ebay.co.uk/itm/311049682509?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The original arm was black & according to the instructions it should be a red one which i have fitted, no i haven`t tried a new set of points, surely if the module was duff it wouldn`t give a spark at the plugs which it does, quite bright spark i also have the plug testers here
http://www.ebay.co.uk/itm/171689611692?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
&each plug shows a bright spark.
Do you know what the difference is between them, Also she starts at the flick of the key if that helps.
Robbie
« Last Edit: May 01, 2015, 08:28:13 PM by flying pasty » Logged
« Reply #25 on: May 01, 2015, 08:24:29 PM »
Dont know about how the module works, just a guess.Think I had 2 rotor arms with mine , and one was different??
« Reply #26 on: May 01, 2015, 08:33:24 PM »
Swap no 1 and 4 plugs over and see what changes. the plug lead tester only show your getting KV to the spark plug, not the spark at the plug
« Reply #27 on: May 01, 2015, 08:45:02 PM »
I agree.I reckon it is electrical.
flying pasty
« Reply #28 on: May 01, 2015, 08:48:10 PM »
Hi Terry
Just been out to the garage & run the trike in the dark up to temp & NO light show around the engine.
How do i know if i have the correct rotor arm for this elec ign , i will swap the plugs over as you suggest in the morning as all pensioners bungalows here so don`t want to upset them tonight,
Robbie
« Reply #29 on: May 01, 2015, 08:56:43 PM »
what ignition system you got make model number
was it complete with distributor and new coil more info please
just read back. I see you have the ignition for a 45d distributor. is that whats fitted to your engine
« Last Edit: May 01, 2015, 09:03:59 PM by terry t » Logged
