steveb263
« Reply #15 on: November 18, 2011, 08:07:48 PM » |
Okay I think a VOTE is need here as to whether I build the prop solid or sliding or is it a case of FIGHT .
steveb263
« Reply #16 on: November 18, 2011, 08:10:15 PM » |
OKAY I think I need a vote here as to whether to build the prop solid or sliding or is it a case of FIGHT
steveb263
« Reply #17 on: November 18, 2011, 08:17:42 PM » |
I am starting to feel like 'MAX HEADROOM' here stupid VIRGIN MEDIA keeps crashing and it's not sending then it is .
steve brock
« Reply #18 on: November 18, 2011, 08:40:25 PM » |
Don't need to slide on a hard tail use ujs..
« Reply #19 on: November 18, 2011, 09:41:37 PM » |
I'm no expert so can only go on my own experience, but I've always used rigid props on my builds with no problems so far. As Terry says, I think you're in danger of over-thinking things here!
steveb263
« Reply #20 on: November 19, 2011, 12:32:10 AM » |
Okay I think you have convinced me that the route I was taking is the correct path and I think you are correct Manky I am over thinking things . It's probably because this is my first build I just want to get it right first time round . I also thank you again Steve for your offer of the prop but I should maybe direct the money needed for p+p towards finishing my trike off and buying the things that I definitely require . No doubt I shall have many other things I will have to pick your brains on but I feel comfortable I am in the right place to do it .
Cheers Steve
« Reply #21 on: November 19, 2011, 12:50:58 AM » |
both ways would be fine, personally i'd use the slide in case me measurements were out
I hate when people compare Lemmy with God, i know he is great but he is not gonna be Lemmy, ever If your Dad hasnt got a beard, you've got two Mums there's no point it lookin' pretty if we can't drive it.
steveb263
« Reply #22 on: November 19, 2011, 01:17:42 AM » |
Cheers Chewie you've started the wheels in my head to rumble again LOL
« Reply #23 on: November 19, 2011, 08:15:16 AM » |
Steve. by the sound of it you don't know what you want. the comments and advice you are getting. is just our own views. and from them it will give you an idea of what other trike builders have done. with this information it will then give you a idea of what you want on your trike. theres no set procedure.it what your happy with. once you have made your mind up stick with it
steve brock
« Reply #24 on: November 19, 2011, 09:07:16 AM » |
This a full trike or a bike trike ?
zakboy
« Reply #25 on: November 19, 2011, 09:31:26 AM » |
whats the diffrence
« Last Edit: November 19, 2011, 09:43:49 AM by zakboy »
« Reply #26 on: November 19, 2011, 09:47:51 AM » |
whats the diffrence the frame. full build or rear end
steve brock
« Reply #27 on: November 19, 2011, 09:50:25 AM » |
I knew that would stir the pot up..
zakboy
« Reply #28 on: November 19, 2011, 09:53:49 AM » |
prop still serves the same function dose it not
steveb263
« Reply #29 on: November 19, 2011, 10:16:26 AM » |
I am only having a laugh with 'Chewie' Terry . My mind has been made up and the direction I had started to go down i.e solid prop has been confirmed . This build is a bike trike Steve , based around a Suzuki GS 650 GT . I was just making fun as this is the problem that has confronted me every time someone new saw my trike , do I go solid prop or sliding prop but as I said a few post's ago I am going with all those who have already successfully built a trike I have finally decided that the solid prop I have been building will remain . It was merely the fact that everyone seemed to have their opinion as to what was best and I just wanted a general consensus as to which way is correct because I didn't want to build something that would not be of any use and hinder the build further . So lets lay this to bed now LOL.
