May 08, 2024, 12:08:39 AM *
Pages: 1 ... 13 14 [15] 16 17 ... 28
Author Topic: Archie's Volksrod  (Read 91656 times)
« Reply #210 on: January 08, 2013, 09:07:02 PM »
Colour is way off yet
Just thought you might have half an idea in your head..........
Need half a brain for that!
« Reply #211 on: January 08, 2013, 11:28:21 PM »
Noooo, only half a brain cell!   Wink
« Reply #212 on: June 09, 2013, 02:40:39 PM »
Put the steering on today and trimmed up the body. Just need to tweak it a bit and then can weld it back on
http://i1019.photobucket.com/albums/af318/archie_837/7FCCE328-EA03-4964-A16E-446177BF1CC6-1312-000002D56F77B270_zps7b2fc185.jpg
Archie's Volksrod
« Reply #213 on: June 09, 2013, 03:14:00 PM »
glad to see your still progressing archie.
« Reply #214 on: June 29, 2013, 04:13:17 PM »
Tacked the body into place today and cut the bracing out - hurrah! I also gutted half a door to trial it in place and square the body up. I needed to do this so the door would shut - due to the channel/bodydrop the door now shut against the floor pan instead of over it.
http://i1019.photobucket.com/albums/af318/archie_837/A0F7CD32-9013-4E30-971A-C895A1D6A2E7-3396-00000BAC549A4209_zps1f87097f.jpg
Archie's Volksrod
http://i1019.photobucket.com/albums/af318/archie_837/8F03FA87-A23C-493F-A152-1B18BD0A787E-3396-00000BAC5CBF9160_zpsb5871c10.jpg
Archie's Volksrod
Not bad for a first attempt
http://i1019.photobucket.com/albums/af318/archie_837/E9282795-82AF-4585-94EB-9B6C76FF6FAA-3396-00000BAC6C0EBA12_zps04179f78.jpg
Archie's Volksrod
http://i1019.photobucket.com/albums/af318/archie_837/2E789FDC-E9B8-4BA1-9DB1-A7AAA6D7242F-3396-00000BAC75E39747_zps02165d8e.jpg
Archie's Volksrod
And then quit while I was ahead. Next up is the other side which isn't so square, so expect that door gap to be waaaaaaaaay off.
« Reply #215 on: June 29, 2013, 06:32:58 PM »
looks good.
« Reply #216 on: July 28, 2013, 06:42:25 PM »
Gutted the passenger door to trial fit it in the hole today. Thought it would be a poor fit' but its not too bad which is good. Next up is getting some sheet and starting to make up the firewall' which would make the body properly solid.
http://i1019.photobucket.com/albums/af318/archie_837/984FF94E-D189-4A31-B9B4-63DB25C465B0-3509-000007116CE08379_zpsa7ca31e4.jpg
Archie's Volksrod
http://i1019.photobucket.com/albums/af318/archie_837/0D073E45-5C96-4902-BA07-E832FE29F80B-3509-000007117B35BC7E_zps817a2d5e.jpg
Archie's Volksrod
« Reply #217 on: July 28, 2013, 06:48:43 PM »
Like that last photo Archie. Coming along nicely mate.
thebigdogsix
« Reply #218 on: December 11, 2015, 06:36:08 PM »
You still got this Archie?
« Reply #219 on: December 18, 2015, 10:59:13 PM »
I do for now.
Daily driver is costing a lot of money at the moment so its sat waiting patiently
« Reply #220 on: November 29, 2016, 01:10:45 PM »
Pulled this apart for the first time in a while. Split the Body from the pan to bolt in some new style heater channels and also fit up a a later gearbox which has longer shafts and spacers to try and widen the track on the rear a bit. Pulling the body was interesting as there weren't really enough to get a safe way to take it off, but off and on it came anyhow.
http://i257.photobucket.com/albums/hh231/archie837/F0428742-5CFD-4551-A9A5-E82DB7E41CC6.jpg
Archie's Volksrod
http://i257.photobucket.com/albums/hh231/archie837/1916F1E5-2C7E-4A8B-BC26-0E2E9009ED5B.jpg
Archie's Volksrod
http://i257.photobucket.com/albums/hh231/archie837/F72BBE4A-842F-43E3-96CD-FB52317BF5CE.jpg
Archie's Volksrod
need to pull the body again as on channel needs cutting and rewelding to get straight then, I should be able to stick the body back to the channels and pull it for full welding.
« Reply #221 on: November 29, 2016, 07:28:41 PM »
I'd forgotten all about this. Nice to see it again.
« Reply #222 on: April 19, 2019, 10:07:41 PM »
Hey guess what! I’ve still got this.
Welded in the passenger door to get the body straight, then took the shell off to get at the wonky heater channel, which was cut and bent to the right shape and rewelded. Then dropped the body on as square as it would go and welded it to the channels as best as possible (I can’t believe I cut so much out) which = one surprisingly unfloppy beetle.
D902-EC82-AD93-4-B7-C-8-CE2-36-FCD1-E0-C7-A6" border="0
« Reply #223 on: April 19, 2019, 10:08:58 PM »
7-FC31-ECD-E5-C5-4-CCD-949-A-1-CB82-A7-F990-B" border="0
AF2-E6-D01-8811-43-CF-95-A4-E5986-BDBE764" border="0
« Reply #224 on: April 20, 2019, 07:54:17 AM »
I'd forgotten about that!
Boy, that's gonna scrape isn't it?!
