Title: HS2 Su Post by: Terrortubby on November 23, 2006, 02:02:47 PM Hi all
I need a HS2 Su carb or a cheap service kit for the same for a reliant engine, I may have a 750 engine in the trike but can't be sure. Any help or even the bits would be most welcome. I can pay for the bits or swap some of the stuff I have lying about the place. I have most of an engine here and a spare gearbox. Cheers Gary Title: Re: HS2 Su Post by: Manky Monkey on November 23, 2006, 02:28:48 PM Hiya, we've got various bits & pieces of carb knocking about, but not sure if we've got a spare complete one. Is there a particular bit you need? If it's a 750 it would've originally run on the earlier Zenith down draught carb.
Title: Re: HS2 Su Post by: Terrortubby on November 23, 2006, 02:53:23 PM Hiya,
Yeah we ditched the Zenith as it was really knackered. it also got in the way of the tank. We have a HS2 on the engine now and even though there are no gaskets on the inlet manifolds as yet it runs quiet happily ::) ::). We decided not to fit the new gaskets until the final assembly. Cheers Gary Title: Re: HS2 Su Post by: flap on November 23, 2006, 07:45:31 PM Don't bother using gaskets between the carb' and inlet manifold and the carb' - air filter, use the blue or red gasket sealer in a tube. Can't remember what its called, begins with a H. Seals better than paper ones. I have several bits of carb' in me garage. What do you need ?
Title: Re: HS2 Su Post by: Terrortubby on November 23, 2006, 08:03:23 PM I could use a needle and main to suit a reliant engine, the su I have is an old one and the needle is worn.
I must say I'm surprised the engine ran at all considering it has no gaskets of any description in the inlet tract at all at the moment. I recon it should run well once it isn't sucking any extra air in. I also need to sort a pancacke type airfilter and element out but looking on ebay and other sites have been totally gobsmacked at the money people want. I'm no miser you understand but some of the prices I have been quoted...I'd want a new carb for. I have been quoted nearly 70 squids for a service kit for my hs2 and the bloke wanted me to tell him what needle I needed. At that price I thought he should know. He purports after all to be the expert. I could use any HS2 bits at all to be honest, I can use the good bits to sort a decent carb out of the bits I have. Cheers for asking. Gary Title: Re: HS2 Su Post by: saddlebags on November 23, 2006, 08:10:48 PM the blue or red gasket sealer of which you speak is called hermetite not sure of spelling though.
Title: Re: HS2 Su Post by: Manky Monkey on November 23, 2006, 09:51:55 PM Try Burlens for carb spares.
http://www.burlen.co.uk/ They're in the Links for Commercial Purposes bit of the forum. The standard HS2 needle's an AAT. We've got AAUs in our trikes, which run much smoother with shorter exhaust systems & more open filters. Start off with the needle seating screw, (the big one in the bottom of the carb), wound out 2 full turns, then adjust as necessary from there. Ska Man runs a simple pancake filter on his blue Reliant, (I'm still waiting for a write up to go with the piccies of it by the way Nige!), with no problems. Always loads at autojumbles. There's another one at Kempton racecourse before Christmas if you're nearby. Title: Re: HS2 Su Post by: flap on November 23, 2006, 10:07:34 PM Got my filter at Beaulieu autojumble. Cost about 15 quid but it is nice and shiny ;D
Title: Re: HS2 Su Post by: Manky Monkey on November 23, 2006, 10:14:53 PM And it's a genuine SU one.
The blue sealant used on Flap's trike was Hylomar -my Hylomar. Now I haven't got any. Title: Re: HS2 Su Post by: flap on November 23, 2006, 10:20:09 PM Its red Hylomar on my trike :P there wasn't enough blue in the tube so I had to buy some :(
Title: Re: HS2 Su Post by: toad on November 23, 2006, 10:21:00 PM i have a complete carb surplus to needs! if ya dont wanna rebuild yours! dont want anything for it! was just about to chuck it in the skip! bloody hate the hs su! the hif versions alot better but you,ve gotta make a new branch pipe to fit your manifold!!!
Title: Re: HS2 Su Post by: ska-man2 on November 23, 2006, 10:33:27 PM Ska Man runs a simple pancake filter on his blue Reliant,
I use a K&N filter. Title: Re: HS2 Su Post by: Manky Monkey on November 23, 2006, 10:41:59 PM Yup, a K & N filter element over a pancake filter.
Ska Man & I are off to "The Motorists Discount Centre" in Newbury on Monday to shop for Cherry Bomb exhausts. Want me to pick up a filter if they've got any? Title: Re: HS2 Su Post by: Terrortubby on November 23, 2006, 11:04:20 PM Yup, a K & N filter element over a pancake filter. Ska Man & I are off to "The Motorists Discount Centre" in Newbury on Monday to shop for Cherry Bomb exhausts. Want me to pick up a filter if they've got any? Not as yet mate, I have a few bits I need to pay for this month. Our local factor lets me have bits on tick now and then and I need to pay him before I spend any more. I also need to send toad some beer money and postage if the carb he has will suit. I'll post some piccys of my carb set up in the morning so you can all see what I'm up to. Cheers everyone for your help so far. Regards Gary Title: Re: HS2 Su Post by: Terrortubby on November 24, 2006, 04:19:23 PM A couple of piccys of the carb. It faces the front of the trike.
Title: Re: HS2 Su Post by: Manky Monkey on November 24, 2006, 06:34:23 PM Same direction mine will face.
Title: Re: HS2 Su Post by: davesatan on November 24, 2006, 09:52:47 PM where are you in the country mate probably got su filter gaskets etc
Title: Re: HS2 Su Post by: Terrortubby on November 25, 2006, 08:55:09 AM where are you in the country mate probably got su filter gaskets etc Hi, I live in the Manchester area. Place called Ashton-under-Lyne. It's the very wet bit just outside Manchester. Cheers Gary Title: Re: HS2 Su Post by: davesatan on November 25, 2006, 09:10:19 AM i live near burnley mate will have a rummage
Title: Re: HS2 Su Post by: Terrortubby on November 25, 2006, 02:47:11 PM i have a complete carb surplus to needs! if ya dont wanna rebuild yours! dont want anything for it! was just about to chuck it in the skip! bloody hate the hs su! the hif versions alot better but you,ve gotta make a new branch pipe to fit your manifold!!! hi Toad, did you get my email ? Cheers Gary Title: Re: HS2 Su Post by: toad on November 26, 2006, 10:08:00 AM yes mate! its the same carb send me your addy and i,ll bung it in the post, ;)
Title: Re: HS2 Su Post by: Terrortubby on November 26, 2006, 11:16:26 AM yes mate! its the same carb send me your addy and i,ll bung it in the post, ;) Thanks a lot Toad, you have email. It's bits of help like this that restore a blokes faith in the idea that bikers/trikers are a brotherhood( sisterhood in case Bobbi sees this)who will help people out without asking the earth in return. Nice one Toad, and all the rest of you that offer advice and encouragement. cheers Gary Title: Re: HS2 Su Post by: Manky Monkey on November 26, 2006, 11:25:39 AM :) Advice & info cost nothing. Can't see the point of keeping it to yourself if it'll benefit someone else & help them get on the road. Same goes for unwanted parts. Better to be used by someone than sat on a shelf gathering dust.
Title: Re: HS2 Su Post by: Terrortubby on November 27, 2006, 10:46:30 AM I'll be posting a list for the bits I have about the place. Anyone needs anything they can have them for the cost of the postage.
Cheers Gary Title: Re: HS2 Su Post by: Manky Monkey on November 27, 2006, 12:56:17 PM That's a good idea -a communal spares bin! I'll have a rummage next time I'm in my lock-up & see what I've got going spare.
Title: Re: HS2 Su Post by: toad on November 27, 2006, 06:51:50 PM yep thays a damn good idea! shall we start a thread on who,s got what???
Title: Re: HS2 Su Post by: Manky Monkey on November 27, 2006, 10:50:41 PM O.K, but no accepting bits then flogging 'em on Ebay!
Title: Re: HS2 Su Post by: Terrortubby on December 12, 2006, 06:04:54 PM I have a spare gearbox,
Do we start a new thread or are you going to put a parts bit on? Cheers Gary Title: Re: HS2 Su Post by: Terrortubby on December 12, 2006, 06:21:12 PM Ignore me ,I just found the other thread.
Cheers Title: Re: HS2 Su Post by: Terrortubby on January 18, 2007, 10:20:24 AM Hiya,
I'm still after a HS2 SU for my little toy. I'm not over endowed with the folding stuff at the moment but can come up with a bit of dosh for the right piece of kit. I did have a reliant box and engine to swap but I think spanners may want them. Cheers Gary Title: Re: HS2 Su Post by: Manky Monkey on January 18, 2007, 03:09:59 PM We've got various parts floating about but not sure if there's a whole one. I'll have a check.
Title: Re: HS2 Su Post by: flap on January 18, 2007, 03:21:28 PM Think I might have one, will have a look.
Title: Re: HS2 Su Post by: Manky Monkey on January 18, 2007, 03:36:24 PM Not my one is it?!
Title: Re: HS2 Su Post by: ska-man2 on January 18, 2007, 08:51:06 PM No its mine.
Title: Re: HS2 Su Post by: ska-man2 on January 18, 2007, 08:52:58 PM It belongs to me.
Title: Re: HS2 Su Post by: flap on January 18, 2007, 10:23:33 PM It's mine :P
Title: Re: HS2 Su Post by: tazet on January 19, 2007, 06:49:15 AM now now children play nicely ;D
Title: Re: HS2 Su Post by: flap on January 19, 2007, 01:15:34 PM Mine mine mine mine mine.
Title: Re: HS2 Su Post by: Terrortubby on January 19, 2007, 11:30:49 PM When you gentlemen have decided on the provenance of the aforementioned goods would the rightful owner please let me know if it's available? ;D
Thanks awfully. ;) Pip pip ::) Gary Title: Re: HS2 Su Post by: Terrortubby on January 23, 2007, 09:35:00 AM I should be able to get away with useing the one on the reliant I just bought. I'd still need one if its a downdraught carb in the car tho cos it wont fit.
Let me know if one of you has one going spare please. Cheers Gary Title: Re: HS2 Su Post by: davesatan on February 01, 2007, 09:54:09 PM i might have one mate
Title: Re: HS2 Su Post by: Terrortubby on February 04, 2007, 02:28:20 PM i might have one mate Hi If you do have one spare could you please let me know how much etc? Thanks Gary Title: Re: HS2 Su Post by: davesatan on February 11, 2007, 08:28:48 PM got loads of bits mate but not a whole one so far
any good to you minisport is only 20 mins away from me in padiham Title: Re: HS2 Su Post by: Terrortubby on February 12, 2007, 11:54:40 AM got loads of bits mate but not a whole one so far any good to you minisport is only 20 mins away from me in padiham Im stripping the one I have in the next few days, I'll let you know what bits are u/s . then if you have the bits we can sort something out. Cheers for taking the time and trouble. Take it easy. Gary Title: Re: HS2 Su Post by: Terrortubby on April 24, 2007, 04:37:02 PM I could still do with one of these if antone has one going cheap.
I need a jet and needle for a reliant mill as the one on the trike was off a mini. No idea if they use the same stuff ??? Cheers Gary |
