May 05, 2024, 07:11:42 AM *
Pages: 1 ... 649 650 [651] 652 653 ... 791
Author Topic: Manky's Pop.  (Read 1555101 times)
« Reply #9750 on: August 27, 2017, 09:25:07 PM »
Actually, that photo looks a lot better than it does in real life.
So- a gearbox question while I'm laying underneath, looking at it.
Although I've swapped the engine for a later model one, I'm still using the same auto box. It's a 3 speed Borg Warner 35 from a Rover P6. The g/box sump gasket's been leaking ever since I first got it & now has a thick coating of oily/road grimey gunge on it.
If I drain the oil & drop the sump do all manner of horrible things happen inside the box? It really needs doing, but will I have to prime it before use or anything like that? I don't want to delve inside the box, just change the gasket.
« Last Edit: August 27, 2017, 09:29:40 PM by Manky Monkey » Logged
« Reply #9751 on: August 27, 2017, 09:37:35 PM »
Moving on with the chassis prep & paint, I need to address another problem that cropped up in that first year of use.
On full suspension travel & full steering lock, the front mudguard struts hit the headlights. It looks drastic, but the only real solution & the simplest, is to cut the h/light mounts off the chassis & turn them forward by 45°.
« Reply #9752 on: August 27, 2017, 09:38:46 PM »
« Reply #9753 on: August 27, 2017, 09:43:56 PM »
That pulls the light further forward & closer to the grille shell. I propped one bonnet side in place to see if I could still open it. I can, but if I moved the mounts round by 90° as I originally planned, I wouldn't be able to lift the bonnet.
I've got a MIG welder, but need to run an extension lead from a neighbour's house to use it.
« Reply #9754 on: August 27, 2017, 09:49:13 PM »
Fortunately, the whole truck's being rewired anyway, so I don't have to worry about cutting the wires.
It's depressing to keep taking more parts off than I'm putting on, but I keep telling myself, every job I do is making it better. It's easy to forget how rough it looked first time around & how everyone referred to it as a RatRod.
Left, (drivers side), light in original position. Right one propped in place in the new position.
« Last Edit: August 27, 2017, 09:51:46 PM by Manky Monkey » Logged
« Reply #9755 on: August 27, 2017, 09:53:26 PM »
Old position, 2 fingers gap between light & mudguard.
« Reply #9756 on: August 27, 2017, 09:54:16 PM »
New position, 4 fingers.
« Reply #9757 on: August 27, 2017, 09:58:50 PM »
Another question.
I want to remove the radius rod, ("split wishbone"). Although I think it looks better straight & common sense says it must be stronger, it's normal practice to cut these & angle the front end, so that the rod runs parallel to the chassis, giving several inches more wheel clearance for a tighter turning circle.
Moving the lights & modifying the radius arms is to address the Pop's huge turning circle. Not so bad on the open road, but manouvring in carparks is just hard work.
« Last Edit: August 27, 2017, 10:03:09 PM by Manky Monkey » Logged
« Reply #9758 on: August 27, 2017, 10:03:54 PM »
Light still looks neat.
« Reply #9759 on: August 27, 2017, 10:07:31 PM »
Would you have enough spare movement in the steering box to take advantage of kinked rods ?
« Reply #9760 on: August 27, 2017, 10:10:35 PM »
The leaf spring hanger bolts through the front of the rod. I seem to remember we had a hell of a job compressing the spring enough to line the bolt holes up when we put it together.
Is there a simple way to do it on my own, remembering I'm taking one side apart at a time? Axle stand under the chassis, wheel off -then what? What part do I need to jack up? Or should it come apart easily if I'm working on one side at a time?
« Reply #9761 on: August 27, 2017, 10:12:39 PM »
Yes Dave -the rods are the limiting factor at the moment. Obviously they'd be internally sleeved & fully welded. I've got a stainless bolt head as a steering stop on the back of each hub at the moment, so should at least be able to remove that. Even if I don't gain much steering lock, I'll get proper clearance around the various steering components.
I'd like to fit extra leaves to the spring to stiffen the front end a little -it gets a bit skittery at 70mph+ & it'd also help prevent the body sagging to one side when there's just the driver in it, (an annoying problem with transverse springs). I may be able to order a stiffer spring from Miles at JackHammer speed shop, who supplied the current one, but obviously I'd have to disassemble the whole front end to fit it.
« Last Edit: August 27, 2017, 10:21:37 PM by Manky Monkey » Logged
Stix
« Reply #9762 on: August 27, 2017, 10:18:31 PM »
Do the same to the light stands as they will take a bit of buffeting and vibration when running down the road
Stix
« Reply #9763 on: August 27, 2017, 10:25:14 PM »
Yeah, but I can only partly sleeve those cos the wires run internally. The mounting arms sit over the front corner of the chassis, so there's only a semi circular hole in the bottom for the wires to drop out of, not a full circle.
Stix
« Reply #9764 on: August 27, 2017, 10:33:14 PM »
Ok just thinking of the worst case scenario and how to avoid it.
Stix
