« Reply #15 on: December 23, 2006, 10:28:37 AM » |
Hey Flappy, whats the Black bowler hat shaped bit???
flap
« Reply #16 on: December 23, 2006, 10:51:58 AM » |
It's a handbrake leaver gaiter.
Did you know I won a Trophy and lost my Cartman hat. Then I won another Trophy. I miss my hat.
« Reply #17 on: December 23, 2006, 11:36:56 AM » |
Bet he's tried wearing it though. Is that Mrs Flap's best dining table? I take it she's out then. It's way too clean to be any of our workbenches. Is it just a wide angle lens or is that shaft bent?!
flap
« Reply #18 on: December 23, 2006, 12:28:49 PM » |
Must be the lens or your eyes.
« Reply #19 on: December 23, 2006, 12:50:52 PM » |
Hi Andy. I also thought it looked a little bent, now wonder the parts were cheap.
« Reply #20 on: December 23, 2006, 01:44:21 PM » |
Don't be rotten you lot! It's just the way the camera flash caught it Flap,!
« Reply #21 on: December 23, 2006, 03:17:56 PM » |
Well, I did hear that Flappy Boy likes to flash at the camera
flap
« Reply #22 on: December 24, 2006, 06:03:05 PM » |
All fixed now. Went over Nigel's and welded a longer narrower bit of metal onto an allready long and narrow prodding stick to poke and push the broken half shaft out from the axle. Manky poked and lifted the broken bit with a screwdriver at one end of the axle tube whilst I shoved the prodding stick in the other end of the axle tube and hit it with a mallet and out it came, twisted and broken. Putting the new one in was so easy, only took a few minutes, tighten a dozen bolts, job done
« Reply #23 on: December 24, 2006, 06:40:11 PM » |
Actually, thinking about it, I'm quite suprised I didn't get poked in the eye with the busted shaft. Squinting down one end of an axle tube while you're at the other with a long steel rod & a hammer wasn't the brightest of ideas. How the hell do they make Landy parts so cheap? An inch thick hardened steel shaft, 2 feet long, machined with splines at each end, 10 quid. The little shiny polished ally hub cap thingies that look so out of place on Flap's grubby old wagon, 92 pence. The plastic bags they came in probably cost more than that.
toad
« Reply #24 on: December 24, 2006, 10:10:05 PM » |
at least you wer,nt holding the bit he was hitting! told ya it was an easy job to do!!!
« Reply #25 on: December 24, 2006, 10:15:03 PM » |
Funny how it's always me doing the holding & him doing the hitting! Yup, an easy job once we'd welded together all the offcuts of steel rod we could find to make a long enough prodding stick.
« Reply #26 on: January 04, 2007, 10:15:47 PM » |
hi flap only just read about your half shaft fun dealt with that problem over a dozen times in the past always had landy's so allsorts of bits inc shafts knocking about so if you ever need owt give me a shout could always send it via manky's employer p.s we have agood landy parts supplier up here .aew paddock motors
« Reply #27 on: January 04, 2007, 10:48:53 PM » |
It's Flap's employer too. He's employed there but doesn't do any work.
flap
« Reply #28 on: January 05, 2007, 02:06:36 PM » |
Cheers spanners, will let you know if any thing else goes bang. Been lucky in the 2 1/2 years I've owned it, thats the first time any things broke
wizzkitt
« Reply #29 on: January 05, 2007, 02:10:29 PM » |
Been lucky in the 2 1/2 years I've owned it, thats the first time any things broke Was it the first time you'd let Manky near it?
