May 22, 2024, 04:54:44 AM *
Pages: 1 ... 5 6 [7] 8 9 ... 174
Author Topic: Manky's XS650 Yamaha  (Read 554953 times)
« Reply #90 on: June 02, 2010, 12:13:33 PM »
looks very much alike to me. how bout a "dead on" and profile shot?
« Reply #91 on: June 02, 2010, 01:16:11 PM »
low tank, same rake but a slightley shorter rear end for me  Cheesy Cheesy Cheesy
« Reply #92 on: June 02, 2010, 08:24:35 PM »
New solo seat arrived today. Slightly bigger than Archie's Highway Hawk one & just half an inch thick. It'll be mounted on scissor springs.
« Reply #93 on: June 03, 2010, 11:30:10 PM »
Cut a few more chunks off the Yam frame this afternoon.
It's now this much lighter.
« Reply #94 on: June 03, 2010, 11:36:46 PM »
Back wheel in roughly the same position as the original swinging arm set-up. This produces a straight line from the headstock right down to the rear wheel spindle. XS650s have quite a high headstock, giving quite a chopped stance already when you remove the standard tank.
« Last Edit: June 03, 2010, 11:41:38 PM by Manky Monkey » Logged
« Reply #95 on: June 03, 2010, 11:37:34 PM »
Just under 6 inches of ground clearance here, so I can afford to lose one or two. That'd mean cutting the headstock to rake the front end out a little. The engine's leaning back a touch, so raking the front would bring it back down level.
Comparing mine to Archie's current XS build, his has a 17 inch rear wheel & dumpy "Upside Down" sports bike forks, whereas I have a smaller 16 inch rear wheel & longer original Yam forks.
« Last Edit: June 03, 2010, 11:42:42 PM by Manky Monkey » Logged
« Reply #96 on: June 04, 2010, 04:45:34 AM »
keep the rake and extend the downtubes  Wink
« Reply #97 on: June 04, 2010, 05:59:16 AM »
Stop buggering around wiv that an get on with your TRIKE!!!
 Grin Grin Grin Grin Grin Grin Grin Grin Grin
« Reply #98 on: June 04, 2010, 06:53:11 AM »
Yep she's gonna have clearance issues I reckon  Undecided low n slow
blair
it looks bigger in water ! !
« Reply #99 on: June 04, 2010, 10:00:29 AM »
wrong way round tbone, he would need to shorten the tubes to lower the front of the bike as the engine is leaning back . go on rake out the front end and slam it to the ground , just go on runs that miss speed bumps
« Reply #100 on: June 04, 2010, 10:22:17 AM »
I think on xs650chopperdawtkawm, there's a proper guide on how to shorten your front forks, which will bring it all level again.
« Reply #101 on: June 04, 2010, 11:59:07 AM »
only if its raked more, or used different forks. If the rake is kept, lengthening the tubes mearly drops the frame lower
« Last Edit: June 04, 2010, 12:05:19 PM by tbone » Logged
blair
« Reply #102 on: June 04, 2010, 02:03:27 PM »
yep thats what i said keep its standard and short tubes lowers the front bringing the engine forward , or rake out the stock and use appropriate tbes to level it of with the rear wheel shaft so the lower tube is level
« Reply #103 on: June 04, 2010, 03:12:37 PM »
1word. Gooseneck.
« Reply #104 on: June 04, 2010, 04:42:01 PM »
Stop buggering around wiv that an get on with your TRIKE!!! Pop pickup!!!!!
Fixed that for you Doc!
