ok i got the bits that i needed. fellow member supplied water pump and rear hose adaptor and i bought hose, clips, thermostat housing, rad flush and coolant. removed rad and fan to get pump of and fitted new one then added pipe so she now looks like this.
my new trike project
then followed the instructions and flushed the system.
took her out on saturday for first run. covered about 20ish miles. she only coughed about 4-5 times and nowhere near as much as before. so and sunday after reading some posts from here i fitted a temporary overflow/expansion tank using a 300ml pop bottle so i could see what was happening. before heading out looked like this
covered another 24 miles. got her up to 60mph at one point for a bit
. she coughed a few more times and did towards the end of the run just slightly over fill the bottle so it sprayed on my leg again. when i stopped back home the bottle looked like this
and in around 4 minutes (time taken to unlock building and open shutters) the bottle looked like this
so i think i will drop all the fluid out and flush with water again.
questions :
is this normal as in spitting fluid?
is it common to need to have expansion/overflow tanks?
any causes for this?
am i going to do any damage by keep riding her?
i have trolled the site over the weekend and am worrying it might be head gasket. partly due to an old post by tbone in this thread
http://www.mankymonkeymotors.co.uk/forum/index.php?topic=6458.msg77818#msg77818. at some point after starting the trike i remember seeing bubbles coming from the pipe in the bottle but cant remember if she was still warming up or warm. i thought at time it might be the air escaping out the pipe as the air expanded in the rad. would that be right? there is no mayo under filler cap and oil on dip stick looks clean as. any other ideas?
still need to set the timing. could this cause the issues?
and whats the test called that a garage can do for it and any idea of cost? cheers again in advance for any answers.
on the plus side.......
WHAT A BUZZ i loved it. didnt want to get off but it got to dark to ride in my tinted glasses. had a racer biker pull up next to me at lights and said he really liked it
and plenty thumbs up whilst riding. she is steady and great on corners. getting used to gear changes and happy to let go of bars with left hand, no wobble. was a bit worrying at 60 bit bouncy bit will get used to it and let a bit more air out the front i think.cant wait to get out again.
