May 14, 2024, 09:47:37 PM *
Pages: 1 2 [3] 4 5 ... 49
Author Topic: my new trike project  (Read 200708 times)
« Reply #30 on: September 18, 2012, 07:51:11 AM »
 Pipe Centre is probably best. Plumb Centres probably only do copper or plastic
« Reply #31 on: September 18, 2012, 10:28:19 AM »
Heres the linkage I built to allow the throttle cable to enter at a better angle instead of vertically.
 My tank is mounted on the back of the trike,but I've seen a few bike tanks with a notch cut out to clear the carb.
« Last Edit: September 18, 2012, 10:33:27 AM by ROD » Logged
digger06
« Reply #32 on: September 18, 2012, 02:46:36 PM »
stick a webber on, no clearance issues then
andyrennison
« Reply #33 on: September 18, 2012, 04:47:06 PM »
the 1 3/8" erw (1" bore) and 7/8" pipe are proving a bit illusive! anyone have a source where i can get about 3m of one and 1m of the other? the guy at my local plumb centre looked at me like i had two heads when i asked for it.
Have a look at this, longer than U need but check out their store.
http://www.ebay.co.uk/itm/150765466486?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
I just bought that for my handle bars, should come in the next few days, its expensive but I hope it will look the part when painted or plated Smiley
PS look for tube, not pipe. As I understand it tube is measured by its outside diameter, pipe by its inside diameter. So 7/8 pipe will be slightly larger outside and may not fit your mounts?
« Last Edit: September 18, 2012, 04:49:19 PM by andyrennison » Logged
steven brock
« Reply #34 on: September 18, 2012, 05:19:40 PM »
1.6mm wall! Crikey mine is about 4.2mm  Shocked
andyrennison
« Reply #35 on: September 18, 2012, 05:24:25 PM »
I did wonder what to get. My current bars aint ev en a mill I don't think.
« Reply #36 on: September 18, 2012, 06:56:41 PM »
Put a spacer between the carb and manafold to move the carb out. or try to get one of these
it moves the carb away from the engine
and it sits a bit lower
twisted
« Reply #37 on: September 18, 2012, 07:30:04 PM »
rod, nice link you made there mate. might look at that.
andyrennison, cheers for that. i will try to mail them later and see if they have 4mm wall tube. good that they do it in shorter lengths. i only need about 48" of 1 3/8" and 51" of 7/8".
terry t, what is that called? and where can i get one? that might give me the space i need for more juice  Smiley
cheers boys this is helping me lots  Grin
« Reply #38 on: September 18, 2012, 07:39:57 PM »
Id use a thicker,rather than thinner walled tube for the bars.
« Reply #39 on: September 18, 2012, 07:58:32 PM »
where the bars you have meet the top yolk they are made of solid bar  Wink Wink machined,,
twisted
« Reply #40 on: September 18, 2012, 08:05:52 PM »
ah cool. the bars on her are cool but if i get a bigger tank on there they might not clear the tank. if i do bend up new bars they will be very simular to the current ones which are very cumfy  Smiley
trikerpete
« Reply #41 on: September 18, 2012, 08:50:03 PM »
So Terry, are you going to tell us where you got it from? Smiley
« Reply #42 on: September 18, 2012, 09:10:31 PM »
It came in a big green box full of parts. i got when i brought a reliant project. Roll Eyes also got a reliant weber carb and manifold.
twisted
« Reply #43 on: September 18, 2012, 10:42:18 PM »
you lucky boy terry t, now i just gotta find me one of those boxes ha ha.
andyrennison
« Reply #44 on: September 18, 2012, 10:51:35 PM »
Oh Bugger, do you guys think Ive bought too thin ??
