« Reply #75 on: March 07, 2010, 07:49:09 PM » |
I agree with Mr T, but can't quite understand just how you could push the splined drive end through the planet wheel? Morrag
geordi
« Reply #76 on: March 09, 2010, 12:49:17 AM » |
We don't understand it ether. I hopped someone here would have the answer
if anyone is in the Essex area and fancies poping in for some help we can provide as much tea and coffee as you can drink
geordi
« Reply #77 on: March 25, 2010, 08:31:05 AM » |
Ok enough its enough, had a play last night and still the same issue,
The axel is welded into the frame so I cant take it apart without cutting into the frame,
As we have drained the oil when we removed the half shafts would this be the issue? (personaly I dont think it is)
Untill we can get this sorted the whole project is at a stand still, Is there a reliant garrage or specialist in the south that anyone knows of that we can contact or take the frame to
thanks in advance
« Reply #78 on: March 25, 2010, 03:52:44 PM » |
Hi geordi. were about in the south are you.there a small garage in portsmouth that specialize in reliants
geordi
« Reply #79 on: March 25, 2010, 04:25:17 PM » |
I'm in Crawley but the trike is in Southend essex
but I'll take it as far as it needs to to get fixed. With it like it is it's no good for nothing
could you pm me there details and I'll give them a shout
VmaxTriker
« Reply #80 on: March 26, 2010, 12:58:35 AM » |
But on the plus side I won sme bits off ebay 2 new Calipers (Part no's lc3434 & lc3435), 2 Carriers and pads Project Resurrection (question page 5) Project Resurrection (question page 5) Project Resurrection (question page 5) How much did they set you back mate (if you dont mind me asking). as im after the same things.
Ignite the Vboost!!!
geordi
« Reply #81 on: March 26, 2010, 07:11:54 AM » |
I think it was £50 off eBay
bargin price.
VmaxTriker
« Reply #82 on: March 26, 2010, 01:20:02 PM » |
Deffo was a bargain mate.. il keep my eyes wide open
« Last Edit: March 26, 2010, 01:22:45 PM by VmaxTriker »
geordi
« Reply #83 on: April 01, 2010, 08:11:22 PM » |
Going to pend tomorrow working on the trike again tomorrow,
If I cant get the rear axel sorted tomorrow i'm about ready to give up,
I'm thinking if I move the bearing 1cm towards the end of the hub it should work, (I hope) Dose the bearing need to rest on the coller?
how do you move the bearing along the half shaft?
thanks in advance
« Reply #84 on: April 01, 2010, 08:46:25 PM » |
hi geordi. the wheel bearings will only go as far as the collar on the half shaft.hope this helps Project Resurrection (question page 5)
geordi
« Reply #85 on: April 01, 2010, 09:15:22 PM » |
Do the bearing need to sit aginst the collar?
how do you move the collar
« Reply #86 on: April 01, 2010, 09:33:56 PM » |
the bearing should be pushed up to the lip on half shaft. you can see the lip on the bottom picture to the right of the bearing it will not push on any more.the collar sit along side the bearing witch then fits into the axle. photos of your half shafts with bearings on might help.are your half shaft the same length
geordi
« Reply #87 on: April 01, 2010, 09:51:13 PM » |
The trike is at a friends so I cant get any pix, Pain I know Yer the halfshafts are the same length, if I can move the colour it could solve all my problems Taking of pix I opened up the rocker cover on one of my engines, and there were some bits loose and broken in there Can anyone let me know what this is (apart from broken) Project Resurrection (question page 5) Project Resurrection (question page 5)
snafu
« Reply #88 on: April 01, 2010, 10:16:47 PM » |
Probably valve stem seals
« Reply #89 on: April 02, 2010, 08:34:00 AM » |
Yup, hard to tell the size from your pics, but looks like a valve stem seal. They go in as fairly soft rubber, but after exposure to heat & oil, come out as hard plasticky stuff. They don't normally do any damage when they break up, but obviously your engine will start smoking once they've gone cos oil from the rockers can make it's way down through the valves into the combustion chamber. Quite cheap to replace & a simple enough job to do.
