kinkytriker
« Reply #15 on: March 07, 2013, 08:28:55 PM » |
thanks, will have to get some measuring equipment lol
« Reply #16 on: March 07, 2013, 10:15:06 PM » |
Just count the teeth against a rule. If it looks like an M8 x 1.25 then it's 5/16" unc
« Reply #17 on: March 10, 2013, 11:30:56 AM » |
Looking good there Steve
kinkytriker
« Reply #18 on: March 11, 2013, 03:22:09 PM » |
cheers, to cold at the min to sit out side and put the axle back in, bloody wind is biting .
kinkytriker
« Reply #19 on: March 13, 2013, 08:53:47 AM » |
breather hole in axle tubes, had a good look round it but cant find one , does any one know where it could be located, or if i should do my own one and where i should drill it thanks
« Reply #20 on: March 13, 2013, 09:37:41 AM » |
It's a 2-2.5mm hole on the top of one of the tubes about 175mm from where the tube goes into the diff. Because it's so small it can disappear with a thick coat of paint.
kinkytriker
« Reply #21 on: March 13, 2013, 05:27:22 PM » |
should i have a hole on both sides, took back to metal on both sides and cant see a hole
« Reply #22 on: March 13, 2013, 05:31:54 PM » |
Theres only a hole in one side. I found mine eventually,and drilled it out bigger to accomodate a breather tube. Otherwise just drill a new one.
kinkytriker
« Reply #23 on: March 13, 2013, 05:35:00 PM » |
thanks, will drill one i think, before i strip all the paint of it
« Reply #24 on: March 13, 2013, 05:51:34 PM » |
Has your axle been 'turned over'? This is done on some 'bike trikes' to get the right axle rotation, or have the tubes been replaced?
« Reply #25 on: March 13, 2013, 07:41:24 PM » |
Good Point ON!
kinkytriker
« Reply #26 on: March 13, 2013, 08:48:08 PM » |
axle is the right way up, its on an 850 reliant, only know that cos i have a suzuki gs850 trike with reliant axle upside down
« Reply #27 on: March 13, 2013, 09:18:45 PM » |
breather hole in axle tubes, had a good look round it but cant find one , does any one know where it could be located, or if i should do my own one and where i should drill it thanks When I rebuilt my axle, I used 6mm wall thickness outer tubes to replace the original 2mm wall ones. I then welded a 10mm o/d breather outlet tube to it which in turn has a K&N filter slipped over it....sorted
« Reply #28 on: March 13, 2013, 09:20:51 PM » |
K&N Filter to fit over 10mm breather tube that was welded to new heavyduty out axle tubes
kinkytriker
« Reply #29 on: March 13, 2013, 09:37:11 PM » |
that looks spot on, will make sure i vent the tube but will go down cheep route at the moment, aint got long till i need to get it to mot before insurance runs out, cant afford to transport it.
