zakboy
« Reply #105 on: December 21, 2012, 07:11:27 AM » |
cheers Old Newbie,a little more to do
zakboy
« Reply #106 on: December 21, 2012, 05:34:00 PM » |
Bit more done on the forward controls
zakboy
« Reply #107 on: December 21, 2012, 05:34:53 PM » |
zakboy
« Reply #108 on: December 21, 2012, 05:36:48 PM » |
just need a little more finishing and polising
zakboy
« Reply #109 on: December 21, 2012, 05:38:52 PM » |
faced up to bike will be bolted to 10mm thick tabs welded to the frame, just ned to make up the brake and gear rods and linkages
hornet6
« Reply #110 on: December 21, 2012, 06:07:58 PM » |
no projects ever finished
zakboy
« Reply #111 on: December 21, 2012, 06:43:16 PM » |
lol cheers john yes bigger shed would be nice i could widden it, a milling machine would be nice
zakboy
« Reply #112 on: December 22, 2012, 04:49:35 PM » |
decided to make some bolt head housings
zakboy
« Reply #113 on: December 22, 2012, 04:55:47 PM » |
« Last Edit: December 22, 2012, 04:59:58 PM by zakboy »
Mendalot
« Reply #114 on: December 22, 2012, 06:38:34 PM » |
Nice machining Sir, feels good, when you turn out a nice bit of work, dont it !!
zakboy
« Reply #115 on: December 22, 2012, 10:36:43 PM » |
Nice machining Sir, feels good, when you turn out a nice bit of work, dont it !! cheers Mendalot ,
trev
« Reply #116 on: December 23, 2012, 12:02:19 PM » |
very good kev.
zakboy
« Reply #117 on: December 23, 2012, 01:01:02 PM » |
hi trev mate,thanks....... but it is a lot easy when you have a lathe
« Reply #118 on: December 23, 2012, 01:47:31 PM » |
I am certain you could do these as a business Zac, saying that most peeps are either skint or want top quality for nothing. I think you are underselling yourself big time saying its easy if you have a lathe, having the ability to put random ideas into working bits is not easy for a lot of folks. I can't count the number of times I try something and either don't like, can't finish or can't afford to factor out. You just pop in the shed and a load of goodies pop out Edit: just to add there are a few others like you on here as well
« Last Edit: December 23, 2012, 01:49:48 PM by nabsim »
zakboy
« Reply #119 on: December 23, 2012, 03:21:21 PM » |
I am certain you could do these as a business Zac, saying that most peeps are either skint or want top quality for nothing. I think you are underselling yourself big time saying its easy if you have a lathe, having the ability to put random ideas into working bits is not easy for a lot of folks. I can't count the number of times I try something and either don't like, can't finish or can't afford to factor out. You just pop in the shed and a load of goodies pop out Edit: just to add there are a few others like you on here as well Hi Nabsim and thank you for your very kind comments, im not sure that if i did this sort of thing as a bussness it would take the fun out of it becurse as a bussness comes pressure, i have done two things in life as a bussness that started off as hobby and an a intrest and when they became a bussness what i had enjoyed as a hobby disapeared, there are a few ideas and things i have in the pipe work that i may start to do to make a bit of exstra cash a few trike and bike add ons..... but we will see kev
