« Reply #15 on: March 19, 2012, 10:54:47 PM » |
Love it !
zx7r-nutter
« Reply #16 on: March 20, 2012, 12:25:21 AM » |
I digress slightly , but as its in the right theme, i thought i would just issue caution about costumes.
In 1961, 87-year-old Harry Meadows, a resident at the Haslemere home for the elderly in Great Yarmouth, England, achieved late-in-life notoriety when he accidentally killed another 3 residents of his care home by dressing up as the grim reaper and peering through the residents' lounge window whilst holding a scythe.
« Reply #17 on: April 02, 2012, 09:12:04 PM » |
Any more progress Dragonwarrior?
dragonwarrior
« Reply #18 on: April 02, 2012, 10:22:56 PM » |
nope not at the moment, just got hold of a zenith stromberg carb and a family member has a coffin shaped dummy tank to hide my electrics. taking the chassis down to bare metal then repainting it. i need to get cracking with it as i want to use it for the butwhy rally in September.
RODeo
« Reply #19 on: April 03, 2012, 06:20:49 AM » |
Yep,you need to get a move on!
dragonwarrior
« Reply #20 on: April 08, 2012, 06:53:29 PM » |
I now have in my possesion a zenith stromberg 125cd carb. the dilema i am in is how to mount it as it won't fit straight on to the manifold it seems to me to need a 90 degree adaptor. would this be something i could make easily or am i gonna need someone to make it??
« Reply #21 on: April 08, 2012, 07:12:21 PM » |
An adaptor shouldnt be difficult...a piece of pipe(90 degrees?) and 2 x endplates.
dragonwarrior
« Reply #22 on: April 09, 2012, 02:32:16 PM » |
thinking about it now it has to be more than 90 degrees is there any design software out there does anyone know of. thanks dragon
« Reply #23 on: April 09, 2012, 02:34:45 PM » |
any pictures of what youre trying to do ,,may help come up with a solution
digger06
« Reply #24 on: April 09, 2012, 02:45:28 PM » |
thinking about it now it has to be more than 90 degrees is there any design software out there does anyone know of. thanks dragon aye, most of us use it on here, its a pen and the back of the fag packet get some pics up,
dragonwarrior
« Reply #25 on: April 09, 2012, 03:04:48 PM » |
this is the carb that i want to fit on a standard reliant manifold
dragonwarrior
« Reply #26 on: April 09, 2012, 03:05:29 PM » |
another view
digger06
« Reply #27 on: April 09, 2012, 03:18:26 PM » |
some 10mm alloy, hole in the middle for inlet, then studs(or threaded holes) on each side of the alloy to match the carb and the manifold holes thin gasket each side, all done,
like a spacer with studs/bolts
« Last Edit: April 09, 2012, 03:21:12 PM by digger06 »
« Reply #28 on: April 09, 2012, 03:28:25 PM » |
Digger..I could be wrong,but..I think the carb has to sit as it is in the pic,therefore it needs an adaptor to fit it to the angled outlet of the su carb?
dragonwarrior
« Reply #29 on: April 09, 2012, 03:36:14 PM » |
yes your right Rod it has to sit how it is in the pic and that is why i asked on here
