May 11, 2024, 04:27:18 AM
General Tech
will not start
Topic: will not start (Read 2111 times)
DIZZY
Ride it like you want it
will not start
May 21, 2010, 07:52:31 PM »
Hi everyone another problem!!
Tried to start my bike today,turned over but wouldnt fire. took out the plugs,cleaned them put on choke started first time ran for a minute or so,started to die so i turned down the choke but couldnt save it.I turned her over 2 or3 times wouldnt fire again so i took out the plugs and found the 2 off side were cover in a dry soot,the 2 near side were wet.
What does this mean?
cheers Dizzy.
Dizzy
gsxrsam
Re: will not start
May 21, 2010, 08:44:27 PM »
sounds like lack of fuel mate, fuel old?
DIZZY
Re: will not start
May 21, 2010, 09:08:59 PM »
no filled up a couple of weeks back
Dizzy
Re: will not start
May 22, 2010, 11:19:04 AM »
If you have a difference between the two sides then what do the two cylinders share? A Coil possibly?
If not fuel to those two carbs?
http://www.choppit.co.uk
Re: will not start
May 22, 2010, 11:21:23 AM »
Sounds like two pots aren`t firing but doesn`t make sense when you consider the firing order. Possible the choke is only working on the two wet ones and the connection has come adrift in the bank of carbs.
Shall ponder this while I beat the f**k out of the virago to find out why my back cylinder still keeps cutting out!!!!!!!
blair
it looks bigger in water ! !
Re: will not start
May 24, 2010, 10:45:17 AM »
pm sent paul
