Title: lights prob Post by: zakboy on May 10, 2011, 09:22:45 AM hi all have a small issue after wiring up my rear lights,have to admit eclectics are not my field when i put my indicators on with the rest of my lights the rest of the lights flicker with them to a small degree is this a earthing issue and how can i cure it .many thanks zak
Title: Re: lights prob Post by: TwistedPatience on May 10, 2011, 10:36:04 AM Sounds like a bad earth, to test run an earth from the battery to the bulb holder if the lights don't flicker them that's your problem.
Title: Re: lights prob Post by: zakboy on May 10, 2011, 10:45:00 AM hi TwistedPatience, i have tried this but still the same its only very slight you have to look to see it dont know it its normal to get a tiny bit or not, there new lights so theres no corrosion prob. cheers
Title: Re: lights prob Post by: TwistedPatience on May 10, 2011, 10:47:20 AM I get a little bit of flicker normally when I havn't charged the battery recently, if it's only slight I wouldn't worry too much about it.
Title: Re: lights prob Post by: BikerGran on May 10, 2011, 10:51:41 AM I get this if the battery's low, try charging it up?
Title: Re: lights prob Post by: spanners on May 10, 2011, 11:05:21 AM it sounds like its just voltage drop is it better when the engine is running at a fast idle speed ?
Title: Re: lights prob Post by: zakboy on May 10, 2011, 12:02:57 PM thanks a lot all, the battery is low,and i have tried every thing else so will leave it thanks again.all the best zak
