« Reply #30 on: September 18, 2012, 07:51:11 AM » |
Pipe Centre is probably best. Plumb Centres probably only do copper or plastic
« Reply #31 on: September 18, 2012, 10:28:19 AM » |
Heres the linkage I built to allow the throttle cable to enter at a better angle instead of vertically. My tank is mounted on the back of the trike,but I've seen a few bike tanks with a notch cut out to clear the carb.
« Last Edit: September 18, 2012, 10:33:27 AM by ROD »
digger06
« Reply #32 on: September 18, 2012, 02:46:36 PM » |
stick a webber on, no clearance issues then
« Reply #33 on: September 18, 2012, 04:47:06 PM » |
the 1 3/8" erw (1" bore) and 7/8" pipe are proving a bit illusive! anyone have a source where i can get about 3m of one and 1m of the other? the guy at my local plumb centre looked at me like i had two heads when i asked for it.
Have a look at this, longer than U need but check out their store. http://www.ebay.co.uk/itm/150765466486?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649I just bought that for my handle bars, should come in the next few days, its expensive but I hope it will look the part when painted or plated PS look for tube, not pipe. As I understand it tube is measured by its outside diameter, pipe by its inside diameter. So 7/8 pipe will be slightly larger outside and may not fit your mounts?
« Last Edit: September 18, 2012, 04:49:19 PM by andyrennison »
steven brock
« Reply #34 on: September 18, 2012, 05:19:40 PM » |
1.6mm wall! Crikey mine is about 4.2mm
« Reply #35 on: September 18, 2012, 05:24:25 PM » |
1.6mm wall! Crikey mine is about 4.2mm I did wonder what to get. My current bars aint ev en a mill I don't think.
« Reply #36 on: September 18, 2012, 06:56:41 PM » |
Put a spacer between the carb and manafold to move the carb out. or try to get one of these it moves the carb away from the engine and it sits a bit lower
twisted
« Reply #37 on: September 18, 2012, 07:30:04 PM » |
rod, nice link you made there mate. might look at that. andyrennison, cheers for that. i will try to mail them later and see if they have 4mm wall tube. good that they do it in shorter lengths. i only need about 48" of 1 3/8" and 51" of 7/8". terry t, what is that called? and where can i get one? that might give me the space i need for more juice cheers boys this is helping me lots
« Reply #38 on: September 18, 2012, 07:39:57 PM » |
Id use a thicker,rather than thinner walled tube for the bars.
« Reply #39 on: September 18, 2012, 07:58:32 PM » |
where the bars you have meet the top yolk they are made of solid bar machined,,
twisted
« Reply #40 on: September 18, 2012, 08:05:52 PM » |
ah cool. the bars on her are cool but if i get a bigger tank on there they might not clear the tank. if i do bend up new bars they will be very simular to the current ones which are very cumfy
« Reply #41 on: September 18, 2012, 08:50:03 PM » |
So Terry, are you going to tell us where you got it from? Put a spacer between the carb and manafold to move the carb out. or try to get one of these it moves the carb away from the engine and it sits a bit lower
« Reply #42 on: September 18, 2012, 09:10:31 PM » |
It came in a big green box full of parts. i got when i brought a reliant project. also got a reliant weber carb and manifold.
twisted
« Reply #43 on: September 18, 2012, 10:42:18 PM » |
It came in a big green box full of parts. i got when i brought a reliant project. also got a reliant weber carb and manifold. you lucky boy terry t, now i just gotta find me one of those boxes ha ha.
« Reply #44 on: September 18, 2012, 10:51:35 PM » |
Oh Bugger, do you guys think Ive bought too thin ??
