May 06, 2024, 03:18:53 AM *
Pages: 1 ... 38 39 [40] 41 42 43
Author Topic: dobbers trike  (Read 164486 times)
dobber
« Reply #585 on: April 22, 2014, 08:20:39 PM »
forced my self to do a bit on the trike today, put the new axle clamp on the other side then made a bracket to keep the handbrake cable in line .
the first attemp was a mile out of line n a bit bulky so made another  from flat bar
        can i have it in 20 Min's?
dobber
« Reply #586 on: April 22, 2014, 08:23:41 PM »
while i was at it i drained the water and took out the rotton coreplug. bit gunged up inside
dobber
« Reply #587 on: April 22, 2014, 08:25:41 PM »
cleaned it up but didnt put the new one in as im going to jet wash the system out while i can.............unless there is a reason we shouldnt.
« Reply #588 on: April 22, 2014, 10:12:58 PM »
I had that core plug blow out on one of my trikes. I was just approaching a roundabout & was suddenly enveloped in steam.
dobber
« Reply #589 on: May 06, 2014, 07:56:31 AM »
went to do a bit on the trike but the sun was out so off to tax the criuser. had a ride over to the squires coffee bar. now moved to a old pub. was packed
dobber
« Reply #590 on: May 06, 2014, 08:00:19 AM »
mounted the fan and rad properly. wire brushed with a brass colored cup in the cordless gave it a smooth enough surface to black up.. used drilled out tap washers to stop vibration. hard enough to not crush but soft enough to help with the vibration.
Chevy Rick
« Reply #591 on: May 06, 2014, 09:59:47 AM »
Just a thought of mine, is that fan going to do any good so far from the radiator Undecided
« Reply #592 on: May 06, 2014, 11:11:47 AM »
  Undecided PM sent.
dobber
« Reply #593 on: May 06, 2014, 06:40:44 PM »
its a lot tighter than it looks chevy rick but also hoping to make a stainless surround to pretty it up and direct the air flow. as O N says the air needs to be funneld to the rad. think the gap from the fan to the rad is about a inch n half.
« Reply #594 on: May 06, 2014, 07:04:20 PM »
I had over heat trouble with my kit car, basically same as your set up. Old guy came by and forced cardboard down the side between grill and rad so all air was forced through rad instead of around rad. Now perfect, have made up aluminum panels, hardly ever runs to hot and fan is now only kicking in in traffic.
dobber
« Reply #595 on: May 06, 2014, 07:12:47 PM »
thats what im hoping to do.  doing it with card will make it easy to experiment then when i have it sussed get down to my mates stainless shop.
dobber
« Reply #596 on: June 09, 2014, 08:27:11 PM »
while I'm too busy to do work on the trike i thought i may get a start on the registration. any advice on my first step,
twisted
« Reply #597 on: June 09, 2014, 09:41:32 PM »
start by ordering both the v55/5, v55/4 and their guides from here
https://forms.dft.gov.uk/order-dvla-forms/
and a built up form from here
http://www.direct.gov.uk/prod_consum_dg/groups/dg_digitalassets/@dg/@en/@motor/documents/digitalasset/dg_065268.pdf
and a msva form from here
https://www.gov.uk/government/publications/motorcycle-single-vehicle-approval-msva-1
get all your receipts together and keep them you will need them to send with your completed stuff to dvla
thats a start mate
dobber
« Reply #598 on: June 09, 2014, 10:27:06 PM »
wow, cheers for that twisted.
ordered the first two [apx 10 days] and printing the others.
whats the process?  you seem clued up with it.
saex69
« Reply #599 on: June 11, 2014, 11:49:18 PM »
Happened to me once after hauling a ford engine from a scrap yard for my brother lucky for me i had a jubilee coin laying around on the floor of my robin van put it in with a little tap of a hammer filled the rad with some water from a stream at the side of the road and off i went on my merry way. Grin
Life is like a s**t sandwich the more bread you have the less s**t you have to eat.
