Just thought I'd give update as i remember things. its an age thing
The finished length of new axle tube, up too the outer face of the hub bearing carrier is 515mm, this includes the "65mm machined end". One other thing, at the opposite end to the "externally machined end" I also machined an "internall" recess of 30mm/+ so the existing hub bearing carrier (which should have about 30mm/- of old axle tube left on it) can be located centrally before welding together.
