« on: May 12, 2015, 01:01:45 PM » |
Hi All. I am looking to replace the front tyre on my trike. I curently have a 100/90-19 57H tyre on. I have been looking at this: http://vintagetyres.co.uk/item/357/350-19--350x19--avon-triple-duty--motorcycle-sidecar--austin-7--road350-19 (350X19) AVON TRIPLE DUTY: MOTORCYCLE SIDECAR: AUSTIN 7: ROAD Type: CROSS-PLY Diameter: 675 mm Section Width: 95 mm Max Speed: 75 mph Max Load: 225 kg Weight: 5 kg Is that the right thing to buy? thanks Andy
Stix
« Reply #1 on: May 12, 2015, 01:11:43 PM » |
Will give you a flatter footprint and more grip as opposed to a bike tyre that has a rounded profile.
Stix
« Reply #2 on: May 12, 2015, 01:35:33 PM » |
I run on the 350-19 AVON TRIPLE DUTY: MOTORCYCLE SIDECAR: AUSTIN 7: ROAD on my gl1000 trike with no problems
« Reply #3 on: May 12, 2015, 02:40:40 PM » |
Thanks guys, that's the reassurance I needed
« Reply #4 on: May 12, 2015, 03:15:40 PM » |
Thanks guys, that's the reassurance I needed If you have any this steering issues this wont cure it. it will help On mine with standard tyre on I had head shake pulling away and when slowing down. put the Avon on then had heavy steering your may be ok
« Reply #5 on: May 13, 2015, 05:49:28 PM » |
The head shake is pretty bad up to 20 so im hoping the refurb of the shocks plus this will help. Worth a try anyway.
skippy
« Reply #6 on: May 14, 2015, 03:15:16 PM » |
should look for radial as apposed to cross ply as the rear will be radial, was tyre fitter for a few years and was a rule imposed due the design [ some thing to do with the way they react to road surface , too many brain cells destroyed since to remember the extract tech side]
digger06
« Reply #7 on: May 14, 2015, 08:59:55 PM » |
two or 3 trikes of mine have been like that, a damper helps, but tbh, once the tyre scrubbed in it was all but gone, personally, I don't like the sidecar type tyre, heavy, and for me, less grip, especially in the wet, I do use my trike quite sportily though
« Reply #8 on: May 16, 2015, 05:45:30 PM » |
Thanks guys. Where might I get a suitable damper?
Stix
« Reply #9 on: May 16, 2015, 06:43:10 PM » |
Go on FB and look up charity for skint trikers, then scroll down and look for Dave Liccle Hippy he has one he is going to put on fleabay
Stix
« Reply #10 on: May 16, 2015, 08:18:19 PM » |
Not a great lover of steering dampers. there fine for the bikes they where designed for but not to try and reduce head shake that's my views I would check rake trail and bearings forks first
« Reply #11 on: May 28, 2015, 07:26:03 AM » |
Steering damper makes a lot of difference sometimes
« Reply #12 on: May 28, 2015, 07:02:19 PM » |
I've been told - but have no experience - that if the damper is tight enough to reduce headshake at low speeds, it will restrict the steering (not in a good way) when moving faster.
« Reply #13 on: June 09, 2015, 08:56:01 AM » |
We fitted a damper on martins trike..which stopped lots of wobble..no restriction on the steering ? After being told that I didn't need to worry as much about rake and trail on a trike as on a bike ? Some so called experts talk the talk...can't beat experience
« Reply #14 on: June 10, 2015, 05:48:11 PM » |
Thought it sounded a bit odd but..... I always tend to expect blokes to be more knowledgeable than me about building things!
