May 18, 2024, 05:09:14 PM
Trike Tech
producing for a laser cutter
Topic: producing for a laser cutter (Read 2764 times)
December 16, 2012, 07:57:25 PM »
Hi All
I found a local small steel shop who will give / sell me steel offcuts. They have also offered to cut up parts using their cnc machine. Whats the usual software to make the files i need to take them, is there some standard?
andbolt0
Re: producing for a laser cutter
December 16, 2012, 08:18:30 PM »
would it not be a good idea to ask the company what files should be used
steven brock
December 16, 2012, 08:47:33 PM »
Most laser cutters use a . Dxf file generated in a basic cad software program like autocad , what are you looking to have cut? I can spare you a few gusset plates
Last Edit: December 16, 2012, 08:51:34 PM by steven brock
December 16, 2012, 11:00:06 PM »
Hi Andy, yes I will be asking them, just wanted to get a bit clued up before I go there. dxf is fine for me, I think I can manage that ok.
Steve, I am having "running boards" and infilled "walls" around the prop in stainless with patterned holes in, I will make them from hardboard first then cad them up I think. They will be pretty complex as I want the holes / motifes to sort of flow with the frame line. The thinking is to set the plates down slightly so they sid below the top of the frame. That way the skeleton of the trike will be on show and contract against the shiny stuff.
steven brock
December 17, 2012, 12:50:02 AM »
Sounds interesting well goodluck it can take quite a while to sketch these things
December 17, 2012, 09:44:17 PM »
Yeah, thats my worry. I can see me setting sail with hardboard / plywood bits on her @)
steven brock
Reply #6 on:
December 17, 2012, 10:49:45 PM »
If you can draw it I can autocad it for ya
Reply #7 on:
December 18, 2012, 11:11:33 AM »
Cheers Steve. I may well take you up on that
steven brock
Reply #8 on:
December 18, 2012, 11:17:36 AM »
Ni prob
