May 07, 2024, 01:58:16 AM *
Pages: 1 [2] 3 4 ... 14
Author Topic: Paulywombats Honda St1100 Conversion  (Read 42964 times)
« Reply #15 on: July 10, 2017, 11:37:00 PM »
It was machined to grip in the lathe chuck to machine the other side.
Yes can see that, but why not just put the shaft in the lathe with the hub assembled on, unless of course it wouldn't go into the lathe shaft?
« Reply #16 on: July 11, 2017, 05:00:45 AM »
Bingo, you got it. Lathe wouldn't take half shaft.
As to further progress, I've just had a little spell in hospital for a minor op.
On the plus side it gave time for planning.
On the minus side, they get a little upset when you drag out the welder.
Living on a wing and a weld
« Reply #17 on: July 11, 2017, 05:53:01 AM »
 Cheesy Hope you're O.K?
« Reply #18 on: July 11, 2017, 03:17:58 PM »
On the mend, thanks Andy.
« Reply #19 on: July 23, 2017, 01:49:49 PM »
Started to clean up fibreglass mudguards today, why are there so many lumps?
Trying not to go through the gel coat and want to avoid tons of filler, and then tons of sanding.
I think a good undercoating and top coats with lacquer will do for now.
Should I stone chip the underside?
« Reply #20 on: August 03, 2017, 03:23:28 PM »
Got my swing arm frame delivered for the second time, following a return to sort out issues. Such as wrong length, despite emailing details. Also diff didn't fit within his metal work.
Any road, diff now fits. Alas, placing straight edge along where axle sits, I can get a 6mm drill under one end.oops. And the two arms where the axle sits are not parallel.
To say I'm slightly miffed would be an understatement.
pics to follow
« Reply #21 on: August 03, 2017, 03:33:05 PM »
Pic of frame
« Reply #22 on: August 03, 2017, 03:33:51 PM »
pic of gap 6mm
« Reply #23 on: August 03, 2017, 03:37:36 PM »
And another view
mrhutch
« Reply #24 on: August 03, 2017, 03:44:53 PM »
 Shocked
send it back..  not fit for purpose..  also looks a tad on the spindly side ??
« Reply #25 on: August 03, 2017, 05:17:46 PM »
Had a reply back from fabricator, Say it has moved slightly in transit.
I have made it quiet clear my qualifications in engineering.
My opening gambit was " ok, that's absolute nonsense".
Can't wait for the reply on this one.
mrhutch
« Reply #26 on: August 03, 2017, 05:48:09 PM »
 Grin Grin Grin Grin
« Reply #27 on: August 03, 2017, 06:08:26 PM »
Still insisting it has moved in transit, what a wally!
Oh well more cost to me
« Reply #28 on: August 03, 2017, 06:53:25 PM »
Surely you can make it yourself ,or at least modify it ?
« Reply #29 on: August 03, 2017, 08:26:28 PM »
Surely, if it's ,moved in transit, that PROVES it's not fit for purpose!
